I did a show on Saturday with resolume 2 beta 2. It went great but I did have a few problems.
Some of my clips blacked out the sceond screen, the only way to get the second screen back online was to reapply the screen settings which reset the projector.
Error message: Error with plugin (I think)
I tried a DV feed, but switching the camera on while resolume was running caused the same problem as above.
Playing back recorded clips from the DV feed also caused the same problem.
All in all though it went very smoothly, I ended up playing for 6 hours and aslong as I didn't use the dodgy clips it was fine. Towards the end of the night I even used some straight DV footage that'd I'd captured from my camera but not resized and encoded to indeo. No problems with that either even with 3 layers and an effect.
great software, and I highly recommend the x-session from evolution as the xfader is great fun!
