R2 Final - Short cut to midi buttons
Vj Blan
Post by Vj Blan »
I Think short cuts still working only 4 keyboard not for midi buttons.
* Using a uc-33
* Travelling 1.000 Km each weekend to do Gigs :cool:
zutim
Post by zutim »
which shortcuts do u mean. on my board everything works but not the effect opacityand bypass on the single layers.
tim
[Edited on 21-12-2004 by zutim]
Vj Blan
Post by Vj Blan »
Effects, Freeframe....
ChrisisForce
Post by ChrisisForce »
I´ve got the same problem with my evolution x-session.
On the right there's a numeric keypad, the key's send out a signal, and the pc receives it but resolume doesn't react.
Somebody got the same problem?
Maybe you Docmotion, you also have got a x-session don't you?
Here's a picture
[Edited on 22-12-2004 by ChrisisForce]
Tom
Post by Tom »
I had the same problem, I now use Bome's Midi translator to work around it.
It lets you turn midi values into key presses.
zutim
Post by zutim »
im working with the doepfer CTM64 and all midi shortcuts for filters work fine excapt the one for " Bypass effect layer 1" and also layer 2 and 3. they are not working and also the keyboard-shortcuts do nothing on that comand.
Vj Blan
Post by Vj Blan »
Zutin,
Here the midi buttons work for slot effects, but don´t work with [ctrl] key to assign the effects to the layers, that´s my problem!!!
vj docmotion
Post by vj docmotion »
yes i have the x-session and the buttons dont work.... but i want to use the miditranslator... i post when it runs and let you know its ok or not
ChrisisForce
@ Docmotion
Thanx!! I'll hear when you've got it working. I think I'm going to try it myself also this afternoon, when I get home ;)
