Hi everyone! So I have a problem. I just made the upgrade to a new laptop with a 4k monitor. My old computer would run resolume with no issues whatsoever, but this time around the resolution for the program is terribly small and I cant change it. I've tried changing the resolution on my computer but no matter what happens it stays the same in resolume. Help? Thanks in advance! (btw, talking about the interface, not the output)
If your laptop is 4K (3840x2160 HiDPI?), you should be able to set the resolution t to HD (1920x1080?) and have the UI look larger. It's obviously not the ideal solution but that should work for you.
