Contoller mapping Prob: Select multiple clips and activate them @ the same time.
HI5
Post by HI5 »
Hello,
im working on my midi controller mappings again.
Using a Maschine MKI & a Maschine Jam.
I would like to implement sth i have to do with my mouse right now:
Select multiple clips in different Layers and fire them all up @ once.
(Without the need of triggering a whole column).
Right now i do that using my mouse. Holding Crtl and click the preview area (bottom) of the wanted clips in the different layers, followed by pressing enter.
I do not find a way to implement that kind of worklflow into a midi mapping.
I tried mapping the previews to light touching the maschine pads and used Bomes Midi Translator Pro to translate a midi command into a CRTL and ENTER command...its not working.... Im not able to select more than one clip.
Seems the mouse click is another event wich cant be emulated in the way i need it.
Any ideas on this?
THX
Jan
Re: Contoller mapping Prob: Select multiple clips and activate them @ the same time.
I don't think this is currently possible just using the interface.
Enter is like a few other keyboard shortcuts, such as the arrow and escape keys, that have a function assigned that cannot be assigned otherwise. This is something we're working on.
HI5
Post by HI5 »
I see. THX for your reply.
if you'd be using beat synced triggering, you could activate multiple clips which would then launch at the same time.
I guess you don't always launch the same clips together, else you could assign the same midi note or keyboard key to multiple clips at once.
HI5
Post by HI5 »
Youre right. I know i could do it that way. But there is a kind of pressure ill feel & i like to relax :)
Correct.
Thx for your ideas.
