Im running multiple system and I seem to have this same issue on every one...
for some reason if i lose projector signal, if a power cable comes out or projecort just gets turned off for what every reason all the out puts get reordered..
for example.. even though windows says I have screen 1 - 2 - 3 - 4 -5 -6 resolume calls them screen 1-4-5-6-7-8 (for example)..
Main screen is screen 1... so I assign the projectors in the order that I see them on the walls.. and for some odd reason that ends up being something like 4-8-7-5-6 (for example)...
real word the last screen lost power screen 6, now the projectors look all out of sequence and the order now is 1-8-6-4-5
anyone know why they screens go out of order? it would be great if the one just went black and the others stayed on... is this caused by windows?
