Hi i recently upgraded to resolume 6 and a new alienware 17r4 with the gtx1080, it works without issue using a matrox th2g dp in the display port, but anything HDMI causes resolume to crash when opening, whether i use a mini display port to HDMI or directly into the HDMI port both crash when starting the application ....but i can plug them in once the application is already open and have no further issue?
That's strange.
Were you able to send a crash report after this crash?
I have sent a couple reports, i removed the aiso folder from the realtek folder location, and disabled the driver...still crashed so i replaced them and enabled the driver again (since it didn't work) and i have not crashed since... wierd?
