About using Resolume with iPad
allanflores
Post by allanflores »
Hi all,
I try to control Resolume with an ipad.
I first tried TouchOS. The most important function for me is the state of clips. (Basically clip on : light on, clip off : light off). After some tests and research through the forum, I realized that this isn't possible. 192.168.0.1 routerlogin 192.168.10.1
That's why I am looking for an iPad midi controller app which is able to understand the 5 midi statues of a clip (or at least on / off), as an hardware controller can do.
Do you know if this kind of app exists?
If not, do you know of another way to control and monitor the state of a clip with an iPad?
Best regards.
Re: About using Resolume with iPad
TouchOSC should work fine with Resolume, except a bug in it which causes long addresses to go out empty on iOS.
Where do you get stuck with it?
