I hear that some users are having problems with my Tunnel plugin displaying only a black screen
We think this is a graphics card incompatibility problem, so it would really help me to find the cause of the problem if everyone could let me know whether the plugin works for them, whether they are on Windows or OSX and what graphics card their computer has in it.
it worked for me the other day when i tried it out for the first time, but have just tried it again and it gives a black screen. if i drop the opacity to ANYTHING other than 100% it just displays the video its on, but without any effect.
Win XP Pro SP2, ATI HD2600 ( 512mg ram ) using Omega drivers. ( not sure if they are the latest ones, will update them )
Yesterday during some more playing around I discovered some strange things with the tunnel plugin...
Some clips (still don't know exactly why) only show a half tunnel... half screen is black, but you can use parameters to turn it upside down etc.. so it's something in the clip itself i think.
GeeEs wrote:Yesterday during some more playing around I discovered some strange things with the tunnel plugin...
Problem solved!... I was playing with 320x240 clips in a 640x480 composition....
Nice to add.. you can play with the scale parameter from the clip/layer/compo to set the visible angle/size of the tunneleffect in this way...
[edit] also tested on my 32bit windows 7(beta) desktop.. (amd64 x2, 4 Gb Ram, 7800GTX) also working fine.
Doesnt work for me, i just get a black screen, ive tried using it as a layer, clip and comp effect, all are just black.
My Sistem:
LG R510
Intel® Core™ 2 Duo P8400 (2.26GHz)
6 Gb Ram
NVIDIA® 9300M (2047MB Hipermemory)
Ms Windows XP Pro SP3
