G, Flash is working for most other user, so I guess you will have to fix that problem by yourself...
have you checked on your installed flash version?
have u installed the flashplayer?
reinstall it and then try playing flashs again...
when i am adjusting the in and out points via MIDI (knobs of my PCR 50), they are not saved, which means that when triggering the clip again it will start from the former in point.
in and out points seem only to be saved when adjusted via mouse drag and drop (the keyboard shortcuts I & O doesn#t seem to work at all).
its so much fun to play around with resolume 2, but everytime i discover a bug, it makes it harder to decide to buy the prog....
hope, the next version will be less buggy....
Testing beta 2.0, very bad behavior in background on my laptop. Sometimes parts of the interface remain on screen, often the preview window still on top of everything, but the worse thing is that there's no cpu power left - task manager showed up after like 3 mins after (ctrl+alt+del) was pressed, just to kill resolume one time, sometimes a bit better, still not good. seems ok on my second computer.
Not sure if this has been mentioned, but I used the 2.0beta for parts of a show this weekend, and had an annoying bug with the property "continue" on clips not working.
I changed the property from "start over" to "continue" (play mode) but that did not work as expected and I had to go back to using 1.5 for the remainder of the night.
hi, i tried the beta version 2, and i cant find the difference filter button on the layers panel. there are new buttons but not this, which is a loss.
i tried to proyect the second screen to s video and it didn't work. can you xplain how to work succesfully with the dual monitor setup?
besides this and all bugs here posted, resolume rocks!
version beta 2 is pretty good , the output to projector is fine although, I can not see the preview window on my screen...(works fine when using version 1.5)
Anyone had this problem ?
Bug or me?
1. I have a problem where an active channel that's playing will go black. The scroll bar indicates it's still playing, but nothing is coming up.
2. Cannot get 2nd monitor to go fullscreen!
This is a BIG problem for live performance. Am not sure if it is Resolume or my video drivers. I'm using a GeForce 4200 Go on a 8500 Dell Inspiron.
Any advice on these issues would be much appreciated.
