Mapio Output Problem
benjo09
Post by benjo09 »
Hi
Im new here so if you meed any more info just ask.
Im using Mapio to map a cube but my output shows both the Mapio output and the resolume output.
For example Mapios output shows over the top of the selected sample.
Can anyone help to just show the Mapio output in the main output
VJair
Re: Mapio Output Problem
Post by VJair »
where have you loaded mapio?
benjo09
Post by benjo09 »
I thought this was where I was going wrong. I've been adding it like a clip as I wanted the ability to easily switch between different maps.
Where should it be placed? I've tried it in the effects of the layer but edit mode wont open when I put it here.
VJair
Post by VJair »
if you add it like that, then the mapping is only applied to that clip.
adding it on a layer will affect any clips played on that layer and adding on the composition effects every clip.
