patchbox and freeframe
VJzoo
Post by VJzoo »
ive been playing with patchbox and ive got it live feeding winamp AVS into resolume using its freeframe plugins.
the only problem im haveing is that the freefarme plugin is a filter so i lose all my other layers of video.
is there any way to get it to show up in soureces under freeframe in sted of being a filter?
edwin
Post by edwin »
the creator of the plugin should change it's behaviour. it's a tiny change. so maybe you can convince him to fix it.
most freeframe hosts don't support the freeframe source plugin yet. but it's a simple and minor difference.
VJzoo
Post by VJzoo »
cool ill have to ask about it :)
Dodo
Post by Dodo »
can you please teach me how you make it work? i'm trying to play with it but it's not working...
i've copied the freeframes in resolume
i've copied the .ape in winamp
i run patchbox
i run winamp... then?
i run resolume and load the freeframe
nothing happens....
thanks
Dodo
ok find out
Post by Dodo »
ok i found out...
just one question... do i have to change with "avs edit" all the existing .apes and save them all, or there is a faster way?
thanks
VJzoo
Post by VJzoo »
you have to add it to every avs
im going to have to do it to over 1000 :(
it aint going to be fun but im not going to do it till i can use it as a source. :)
mokiloke
Post by mokiloke »
Ok guys pats on the back for working it out, but can you tell us how its done step by step.
Im sure that you can download a rename utililty easily enoughm, to enable relabeling 1000 files tho, or am I missing the point.
