Record problems
Re: Record problems
Resolume stops recording if the system almost runs out of RAM. Intermediate buffers are stored in RAM and another thread simultanuously compresses and writes data to the disk. If the disk writing thread falls behind more frames have to be stored in RAM. After a while there won't be enough RAM available anymore and it stops recording. Maybe your cpu is to busy or you are recording on a high resolution that makes Resolume stop the recording. Check your available RAM when Resolume is running.
Re: Record problems
what you suggest to fix this problem,to record without stoping
this is my
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4000+, MMX, 3DNow (2 CPUs), ~2.1GHz
Memory: 1024MB RAM
Page File: 400MB used, 2054MB available
this is my
Memory: 1024MB RAM
Re: Record problems
1gb of ram is not very much these days. i say go for 2 or more GB if you can.
Orubasarot
Re: Record problems
wow love this performance..outstanding
Orubasarot
Re: Record problems
hey, this got me thinking.... and i think i cracked an EPIC idea....
Orubasarot
Re: Record problems
this or blackberry curve or blackjack 2 can't make up my mind. i dont care about the bells and whistles!! ...... anyone give me some thought plz!!
- rxfromparis
Re: Record problems
I have been able to sucessfuly record 720p video wih Avenue 3.1.1, more than 3 mn worth. My harddrives are formatted NTSF and i have 4 go of mémory. It would be nice to find a solution for Fraps
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
VJ Rhett Bice
Re: Record problems
Is there any new information on this? I am having the same problem. I never had any problems recording out from resolume 2.4 and I'm using the same computer. I wonder what has changed between the two versions?
I"m using a PC.
I"m using a PC.
VJ Rhett Bice
Re: Record problems
Doh. I think in my case it's definitely ram issue.
Re: Record problems
Keep the taks manager (Activity monitor on OSX) open while recording in Resolume. Check the amount of RAM resolume is using and see wether it's eating all the RAM. If it stops while there is still enough RAM we'll have to check if something else is wrong.
