If you have too much time, you could implement a function that allows the user to collect all the files used in a deck and saves it to a folder. this would sometimes save a lot of time.
keep on rockin´
chris
yes. it woul also be cool if you could link together many decks when using the random/chaos function; just 20 clips isn't very many if you're a lazy vj and you want to disappear for an hour or so...
