if you do it live then just map the bpm tab to a button and do it by hand... it will be much better then a programm trying to find the bpm in a audiostream...
~Berlin~
Thanks. Is there a good way to transition from BPM coming from my virtual Midi cable (during my DJ set) to Beat Tap. I find the BPM sync clips stop (per settings) and/or won't play once the DJ software stops sending midi. I will be DJing the breaks for them.
