speed accuracy problems
it would be great to be able to type in a value, because for the moment the speed slider has only got increments of 2 (25 ftps or 23 ftps) or sometimes 24 ftps or 22 ftps.
It would be good to be able to load the same video clip in the 3 layers f1, f2,f3.
i realise it is possible to do so by duplicating that clip renaming it,
but isn't very practical for a live gig ...
db
Hi Doofboy,
you can just load the same clip in another channel. and assign that channel to layer 2.
Resolume only prevents you from using the same channel in different layers, it has nothing todo with the file itself.
but if you use the same clip in 2 channels or more, they run indepently. it would nice if they would be scynchronised, for example to use the transitions, with the same clips with different effects apllied to it.
Thanks Edwin ,
Yes of course you can have deck full of the very same clip,
How embarassing....please delete the message above...
yes, vjing is now easier to me....
Reso 2.1, Rocks...I don't believe i'm asking for more....
