Higher Resolution Masks?
lotech
Post by lotech »
Is there a reason why masks have to be 320x240? Jaggies on the masks suck.
Can you add support for higher resolutions? Support for 640x480 & 720x576 would be really useful.
edwin
Post by edwin »
hi lotech, just create your own masks in the resolution you use most and drop them in the mask folder.
cheers
Edwin
lotech
Post by lotech »
Cool, thanks - you should update the manual so it says this - at the moment it says 320x240 only.
