Hi, i'm running a quartz 3d map out of resolume which has 32 points to control the points of the verticies now because there is no scroll bar on the params that you pass accross to Res it makes it tricky to access them all it would be a really handy feature if you made a scroll bar on those paramiters. so that you are not limited to the amount of controls you have over your composition
