Enttec OpenDMX USB
rolandmc
Enttec OpenDMX USB
Post by rolandmc »
Hello, I'm wondering if the Enttec OpenDMX USB is compatible with Resolume Arena 4. I know that the DMX USB Pro is, but I don't know about the OpenDMX USB. Here's a link to it: http://www.enttec.com/?main_menu=Products&pn=70303
I know that the the DMX jack is for output, but I have a 5-pin male-to-male adapter that I can use.
Thanks in advance for the answer.
synapse_gh
Re: Enttec OpenDMX USB
Post by synapse_gh »
What are you trying to achieve?
If the goal is to get a DMX signal into your Resolume machine, it'll probably be much simpler to use Artnet...
I think that that adapter is an output only box...
levon
Post by levon »
not sure about the OpenDMX, i have a USB DMX Pro, and that works either as an input or an output... and works with Resolume Arena... though i havent really played around with it very much
Stafis
Post by Stafis »
It says
DMX port (output only)
in the dokumentation.
/Stafis
