All Menus & Windows Open At Same Time
vectorfuton
Post by vectorfuton »
Having a weird issue, and not sure what prompts it, but sometimes I'll be using the file explorer menus / tabs, and instead of disappearing when I move from tab to tab, Resolume accumulates them until they take over a bunch of screen space, and I'm unable to click / use the UI properly and then have to quit Resolume (ctrl-alt-delete as the issue also prevents the 'Quit' button from working too apparently)
Re: All Menus & Windows Open At Same Time
Yeah, that's an annoying one.
We're working on it.
7.1.2 should work fine meanwhile. You can get it from the bottom of our download page.
vectorfuton
Thanks! I looked around forum briefly but didn't see it mentioned elsewhere. Looking forward to the fix, as the increased efficiency will allow me to more quickly design templates and contribute to the community! :D
vectorfuton
Thanks for the fix!
