A frequently useful input control is the ability to choose a blend mode for a VideoMixer. This can be achieved using a Choice In and a lot of patience assigning options to integers that match blend modes, but this is then specific to a particular version of Wire (to the blend modes available for that version). If the Wire version changes this can break.
It would be handy to have  a dedicated Blend Mode Chooser input control that has the correct named blend mode Integer choices for each particular version of Wire, and is guaranteed to work correctly on version upgrades.
									Wire: Feature suggestion: Dedicated per-Wire version chooser input for blend modes
Darren Kelly (PLAYlogo), Webel IT Australia
