ipad-layout =)
dbiz
ipad-layout =)
Post by dbiz »
here's ,y first layout for touchosc 1.6.1 working with resolume =)
thx to Digital Gigalow for ispiring me ...
feel free to download and improove it and let me now!!!!
greetings from Italy :geek:
dBiz
rrresss.zip
resolume touchosc editor layout ...
(4.8 KiB) Downloaded 3391 times
dbiz
Re: ipad-layout =)
Post by dbiz »
p.s. a video can found be found here =)
http://www.youtube.com/watch?v=eoMOvj8SPUU
edwin
Re: ipad-layout =)
Post by edwin »
hi dBiz,
The layout works great, just installed on my IPad.
Thanx for sharing!
dbiz
Re: ipad-layout =)
Post by dbiz »
a new update of my ipad layout -
fix
- better fx page
- dashboards
enjoy and feel free to customize =)
have a good time
dBiz
rrresssb-2.zip
beta 2 - enjoy =)
(5.16 KiB) Downloaded 2363 times
dbiz
Re: ipad-layout =)
Post by dbiz »
new update =)
- fx page
- dashboards =)
enjoy!!!!!
dBiz
rrresssv3.zip
resolume layout v3
(5.89 KiB) Downloaded 2623 times
ryazwinski
Re: ipad-layout =)
Post by ryazwinski »
These layouts are .xml files, but the touchosc layout editor on my mac seems to use a binary format for layout data.
How do I import the ipad layouts to the editor? Help :)
schmigel
Re: ipad-layout =)
Post by schmigel »
Very nice layout!
Maybe you should post the mapping file, to us understand better how the layout works.
gradek
Re: ipad-layout =)
Post by gradek »
ryazwinski,
there seems to be problem with OS X and unzipping .touchosc files for some reason it extracts the binary into an xml format. the .touchosc extension become a folder with the contained file. If you extract the same zip on a PC you won't have this problem. I can't seem to figure out why OS X started doing this, it seems to be a new issue perhaps with OS 10.6
you can do a test this yourself by zipping your own .touchosc layouts and then extract them again. you will get a folder with a .xml file. its really strange. Only way around it is zip the .touchosc file in a subfolder.
-Martin
gradek
Re: ipad-layout =)
Post by gradek »
I have attached a OS X friendly version of the zip file. All I did was download the fie on a pc and reziped the same file in a sub folder. This should extract find in OS X without converting the .touchOSC file to a .xml.
rrresssv3_osx.zip
resolume layout v3 for ipad repackaged for OSX.
(6.07 KiB) Downloaded 2655 times
ryazwinski
Re: ipad-layout =)
cool that worked - thanks... now to get the ipad talking to resolume ;)
