maybe i am blind, but....
				chenthemagician
Re: maybe i am blind, but....
Just to add to it tho, as well as advancing the clips in program, do it on the preview as well......so you would have the ability to preview the clip instead of triggering it live when scrolling thru...
									HP Omen
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
Livid OHM RGB Controller
Creating Solutions, Tailored to your needs!
Repping from the 876 - Jamaica "Out of Many, One People"
						8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
+1!!ust to add to it tho, as well as advancing the clips in program, do it on the preview as well......so you would have the ability to preview the clip instead of triggering it live when scrolling thru...
Yes, I want to use an endless rotary encoder to navigate and preview clips, and then a midi button to trigger it to the active layer. This way I have no need to use mouse anymore!
Please please please
@Drazkers: is it possible to scroll over 128 clips? Tried a couple of settings but it keeps stopping at 128. Is this a setting i should change in the midicontroller or is this not possible at all due to limits of cc/midi?
