If I go with the 1080 GPU, and the X4, are each of the X4 individually assignable in resolume? So I will have 8 separate assignable outs in resolume if I go with 2 X4. And because there is another output on the 1080, I have more expansion room.
I would recommend going with the Fx4 rather than the X4 but either way, each Datapath will show up in Resolume as a display. You program the Datapath EDID and assign the 4 outputs directly in the unit.
How do I now handle inputs, would like to be sdi.
Why? Is that because you can go a long distance?
