Anti Aliasing option for slices
Hello Resolumes,
it would be great to have an anti aliasing option for slices inside advanced output.
Why?
There are often visible "stairs" on the slice sides when the orientation is not 100% vertical or horizontal.
(picture just for the guys who don't know what I mean...) ;)
Greets
pfelberg
Re: Anti Aliasing option for slices
Post by pfelberg »
+1
cvanhoose
Post by cvanhoose »
+1
HerrNieDa
Post by HerrNieDa »
if it makes sense to the situation you can meanwhile use a blur effect with discreet settings! ;)
but this won't work with the advanced output sclices... only with mapio or keystone effects.
vvvv would also be a workaround meanwhile
As you said before :)
"this won't work with the advanced output" ....and even if this could work...the blur fx would also distort the clip itself. ;)
vj granda
Post by vj granda »
+1.
HerrNieDa
Post by HerrNieDa »
cosmowe wrote:As you said before :)
of course, but i thought it may doesn't matter (with your footage :p)
@NieDa: :lol:
svoboda
Post by svoboda »
+1
We'd very much like to add anti-aliasing to the advanced output, as well as Resolume in general. Nobody likes jaggies. At this point, we can not do this without slowing down the FPS to single digit numbers though...
