Record your shows?
yugpmoc
Record your shows?
Post by yugpmoc »
Do you record your show? How? Hardware device, another PC running capture? SD, HD?
I just went shopping for a nice media player / recorder with a SSD... And I can't find one.
What's everyone else out there using?
-yug-
LXConcepts
Re: Record your shows?
Post by LXConcepts »
resolume can record it's own output...
preferences -> general -> record video (or audio)
Lighting and media server design
HerrNieDa
Post by HerrNieDa »
the problem is that this function
- doesn't has a fixed framerade
- won't record very long.... especially not a whole show ;)
best way is to record with a video-recording device or an extra computer with video-grabber.
maybe tools like fraps (screen capture software) work also, but i don't think they can record the second output screen for example.... there are problems for sure ;)
drazkers
Post by drazkers »
Output via HDMI into a splitter and loop it back into a capture card onto another box. Blackmagic intensity pro works great. If you have a dedicated recording drive you can do it on the same system.
Fraps works on a second screen, I've used it to record content created in resolume that may be too stressful for a weaker system.
You can also use sypthon recorder on mac, I used that to get quartz composer content onto pc boxes.
