Screen Display resolutions
manmachinemusic
Post by manmachinemusic »
Hello everyone
I clicked on every single thing pertaining to display settings but to no avail can not get Resulume Arena 4.1.6,
to give me a 400x 400 display in the advanced screen display. The only option I'm given clicking on the display tab,
is 1024x 768 or 1680 x 1050. neither one will suffice. The background is a bit small and cutting away part of the composition. Could someone help? i'm really stumped on this one. I'm a novice but pretty familiar with resolume. I started with Resolume 3 a couple years back and now have ventured into the mapping aspect
Macbook pro 2.3 ghz intel Quad core i7
8 GB 133 mhz DDR
OS X 10.7.5 Lion
pfelberg
Re: Screen Display resolutions
Post by pfelberg »
manmachinemusic wrote:Hello everyone
The advanced output will use the resolution available from your display devices.
1024x768 is most probably related to your connected projector resolution;
1680x1050 is most probably related to your first display output (your monitor)
Just select your projector as output and play with it.
Advanced output is not related to your composition size.
If you need 400x400 output, just adjust your slice to that size in advanced output.
