Has anyone done research if cameras like GoPro or Sony HDR-AS100/AS30V could be used as live video sources for resolume?
-Tomi
Could Wi-Fi enabled action cameras used as live video source
Re: Could Wi-Fi enabled action cameras used as live video so
Until 200 people with wifi enabled phones show up.
It is possible to get your GoPro via Wifi as a Stream on your Computer...
i never tested if there is a way to get this Stream into Resolume becouse with the Delay you get ( ~3-4sec) its not usefull for me....
~Berlin~
~Berlin~
dirtyjohn_lv
If you have a mac you can use AirBeam
http://appologics.com/airbeam
x2 on the lag/delay
PaulSwanson
Hello!
Thanks for sharing you solution. I am seeking to know the answer to this issue as well. I might want to try these on my action camera.
I was successfully able to stream my phone/tablet cameras using wi-fi. Or even mirror the device screen it self to the big screens. But I was obliged to use a stand alone connection, out of my Resolume processing.
Through Resolume? It is just another step. My solution?
EzCast
EzCast is the same as ChromeCast, but better, I think.
You can connect EzCast's HDMI connector to your external capture device. Done!
I couldn´t do the final step thru Resolume because Resolume it is not fully compatible with the Avermedia U3 capture device.
EzCast
Use software, which can receive stream and route it to resolume, I know one - vmix. vmix.com
