When using the advanced output
in whichever screen I add a crop layer, once i exit out the screen turns black,
then when you go to the composition layer and reduce the opacity the screen where the crop layer is it behave inversely
I am able to replicate this in any composition
This does not happen in 4.1.9
The mask layer works fine
This is on a MAC Retina Pro 2013
Resolume Arena Version 4.1.10
Mavericks
Issue Advanced out put in 4.1.10 Crop Layer
Re: Issue Advanced out put in 4.1.10 Crop Layer
Yes! We noticed this ourselves yesterday as well. We're on it!
in addition also
when in advanced output
- Selecting Show display and slice info also blanks out all the screens
I just noticed this as well!
Is there a way to download 4.1.8 so that i can go back to using the crop tool normally? I love the new bells and whistles but really can't use the advanced output with how it is. thanks in advance.
Whoops i just found it under the avenue list! Thanks.
Please keep us posted on a fix for this problem.
