Hi, I just bought resolume arena for my project, but sudently i found out that the datapath card sd4+1s doesn't work.
The exact issue that its works partially. DVI input works, but not 4 sd inputs.
I also found out that another datapath card with 2 sdi inputs works well, its flipped but works
Without support for datapath sd4+1s the program is useless for me.
Please advice,
If there is no solution, please tell me how I can recieve money back.
Regards,
George
Datapath Card
Re: Datapath Card
So with datapath cards resolume uses direct show. So if one datapath card works the other should be handling it as well.
Did the datapath 4+1s work in any other programs? Can you send a screen shot of what not working looks like?
Also when a program has a free demo I tend to test my setup with the demo before paying a bunch of cash. Its a great way to test configurations.
Re: Datapath Card
Hi, thanks for reply
Cant make screenshots right now but the problem that arena sees 4 sd inputs, but when i pick one of them its just remains black
In other apps like dataton watchout and arkaos media server it's works flawlessly
I played a lot with demo version, tried bunch of different input cards like blackmagic, avermedia and 2 other datapath cards, all worked ok, some of them needed to customize in arena but generally i saw picture from all of them. So i bought the app and ordered sd4+1s card which i got today and boom it doesn't work
Very frustrating but i hope devs will find a solution for me
Regards,
George
Regards,
George
Re: Datapath Card
Datapath cards are not natively supported on Res 4. Full support is coming in Res 5, but that doesn't help you now.
You can contact us at mail@resolume.com.
