Problems with BMD capture cards configuration
manoloumana
Post by manoloumana »
Hi everybody,
I'm using the blackmagic capture cards (mini recorder and extreme), and they work great, except that when I reopen a composition they don't save any configurations, even if I save the project before I close it, so I have to re configure the capture settings every time I open the compositions.
Is there any way I can fix this?
Thanks for the help!
Manuel
drazkers
Re: Problems with BMD capture cards configuration
Post by drazkers »
I thought this was a bug in an earlier version. What build do you have? 4.2?
Ladin
Post by Ladin »
Hi Manuel,
May I ask you? If you are using BM minirecorder, what is your input lag??
