Hello.
An important question.
Will the subsequent version be a 64bit version?
Using the existing memory full?
Thx
						Resolume 6 64bit?
Re: Resolume 6 64bit?
+1 for 64 bit
Constantly getting low memory warning when doing complicated high res stage work.
- Programfeed
Eventually Avenue/Arena will be 64-bit, we just don't know when. Keep in mind that they have to rewrite for both Windows and MacOS. Also, as I understand it, there are (or were?) some compatibility issues with plug-ins and other playback components that needed 32-bit support. I'm sure they're working as hard and fast as they can on it.
Do you have any first hand knowledge of this, or is this speculation? I ask because I have been searching to see if Resolume is even working on a 64-bit version and so far I haven't found any direct evidence.Programfeed wrote:Eventually Avenue/Arena will be 64-bit, we just don't know when. Keep in mind that they have to rewrite for both Windows and MacOS. Also, as I understand it, there are (or were?) some compatibility issues with plug-ins and other playback components that needed 32-bit support. I'm sure they're working as hard and fast as they can on it.
You did not find evidence? Well, where did you found 32-bit modern Mac OS?
For sure Resolume works in 64-bit OS, both Mac and Windows. And memory manadgement under Windows is terrible.
Recently had an event, not so big, just 50 columns and 5 layers, but 5 screens mapped in 4k with Datapath FX4. After some time, fps was droping from 50 to 15. Deck switching helped, so i splitted content on two deck. Ok, i got back stable 50 fps, but Resolume crashed midshow when i switched to second deck. I was very angry. Never do event without backup. Fortunatelly i had backup machine. But i do not like how Resolume works in Windows.
He means 'working on 64 bit' as in 'is the Resolume team working on rewriting the software for 64 bit'. Not as in 'does the software work on a 64 bit OS'.
And the answer is yes, we are.
Joris wrote:He means 'working on 64 bit' as in 'is the Resolume team working on rewriting the software for 64 bit'. Not as in 'does the software work on a 64 bit OS'.
This news is making me irrationally happy.
- Yu HaiChuang
thank you all!Joris wrote:He means 'working on 64 bit' as in 'is the Resolume team working on rewriting the software for 64 bit'. Not as in 'does the software work on a 64 bit OS'.
Very much looking forward to!
