Hi everyone,
so i'm playing around with DMX input. I am using a grand MA2. Now i've got the following issue:
I start a clip in Layer 1. I use the Group Shortcut, so that i can switch between the clips by changing the value of my DMX channel. My next step is a jump to another clip in Layer 1.
So in my sequence on my lighting console I've got two cues: Cue 1= Clip 1 ; Cue 2=Clip 2
When I activate cue 1, clip 1 is played. When i go to cue 2, clip 2 is played. NOW i go to cue 1 again, nothing happens(that means, clip 2 is still running), I go to cue 2, nothing happens. AND NOW!!!: I go to cue 1 AGAIN and the clip is played. So I have to change the value on this channel twice to jump back to my clip 1. I get the same result when I use more cue and more clips.
Why is this?
Thank you.
						DMX Input BUG?
Re: DMX Input BUG?
Hey I wrote a response earlier but now remember a bug explaining this exact behaviour. You can’t go back but if you go forward you can.Lukikabuki wrote:Hi everyone,
Why is this?
Thank you.
What version are you on?
