Hi all,
GFX MODEL: MSI GTX 1060
DRIVER VERSION: 388.13
VERSION: RESOLUME 5.14
SCREEN SHOTS are attached for your reference.
I tried to set a 7680 x 1080 resolution from Wall Designer for my Datapath FX 4.
Everything on Windows are detected correctly.
But when i look at the Advanced output inside Resolume, the DISPLAY 2 output is detected wrongly.
What may have happened?
Thank you.
*FIXED - DUE TO WINDOWS SCALE * ADVANCED OUTPUT RESOLUTION DETECTED WRONGLY
Re: ADVANCED OUTPUT RESOLUTION DETECTED WRONGLY AFTER DATAPATH FX 4 CONFIGURATION
Your scale is set to 150% instead of 100% in Windows.
Thank you! Yes! Fixed! Allow me to offer you a drink when i visit America!
