v5.1.4 auto shut down upon loading
ranvier
Post by ranvier »
Hi all,
The following is the specification of my rig:
Intel Core i7-8700 Processor (3.20Ghz, 12MB) c/w 16gb ram
MSI Z370M Gaming Pro AC LGA1151 DDR4
500GB SSD Hard Disk / Intel 1219-V Gigabit LAN
Intel Dual Band Wireless-AC8265, Bluetooth
Asus DRW*24D5MT 24x Sata Internal DVD Writer
4x USB 2.0 / 8x USB 3.1 (Gen1) / 3x USB 3.1 (Gen2, A+C)
MSI GeForce GTX 1060 Gaming X 6G
Preloaded with Win 10 Pro (64bit)
I can use the software.
But i have to continually try loading the software, because once the logo and black colour interface is on the screen,
It will automatically be terminated and fade out and show my desktop again.
I have to try a few times before the software can load properly.
Once loaded it's stable.
I'm very concern... what can i do to find out what is causing this or anyone came across such behaviour? And have a solution to this problem?
Thank you!
