how do i debug an FFGL?
shimla
Post by shimla »
i'm kinda new to writing FFGL plugins and xcode / visual studio so bare with me.
when writing stuff in juce i can run the app in debug mode in my IDE which makes debugging very easy. But i don't know how to debug an FFGL that way.
In order to debug my current plugin i've created a 'console' project version where i kinda debug my classes because i can cout them. but that's a bit redundant as i constantly have to switch projects just to debug them in a console.
so yea, what's a good method of debugging your FFGL project
Re: how do i debug an FFGL?
In VS, you can choose Debug > Attach to Process and pick Resolume from the list.
Then all your breakpoints will hit when you use the plugin in Resolume.
Xcode has a similar function, but I don’t know what it’s called or what menu it’s in from the top of my head.
Jichak
Location: https://diceus.com/are-ukrainian-developers-good/
Post by Jichak »
Joris wrote: Sun Apr 28, 2019 10:51 In VS, you can choose Debug > Attach to Process and pick Resolume from the list.
Thanks for this answer.
Menno
Post by Menno »
alternatively: in visual studio you can edit your plugin's property pages to launch arena.
right click the project > properties > Debugging
fill in the command to target the arena executable
fill in the working directory to be arena's executable directory
this way you can f5 your plugin project and it'll launch arena and attach to it automatically
You can also append the path to the composition file you want to open after the Command and then when launching your plugin project it'll make arena automatically open that composition.
subpixel
Post by subpixel »
Great tip, Menno! I thought there should be some way to do this, but didn't read whatever fine manual exists for Visual Studio.
I have addressed this problem by sourcing some code from the interwebs that launches the debugger from within the plugin.
Next question: how can we get Resolume to start without the splash screen? Trying to debug with that taking over my screen is somewhat annoying!
subpixel
Menno
Post by Menno »
You cannot start without splash screen. The splash screen should go away when you click though. Maybe simulate a mouse click yourself?
Code: Select all
enum MouseKey
	MK_LEFT,
	MK_RIGHT,
	MK_NumKeys
enum KeyDirection
	KD_PRESS,
	KD_RELEASE,
void InputDispatch::SendKey( MouseKey key, KeyDirection direction )
	INPUT inputEvent;
	inputEvent.type = INPUT_MOUSE;
	inputEvent.mi.dx = 0;
	inputEvent.mi.dy = 0;
	inputEvent.mi.mouseData = 0;
	switch( key )
	case MK_LEFT:
		inputEvent.mi.dwFlags = direction == KD_PRESS ? MOUSEEVENTF_LEFTDOWN : MOUSEEVENTF_LEFTUP;
		break;
	case MK_RIGHT:
		inputEvent.mi.dwFlags = direction == KD_PRESS ? MOUSEEVENTF_RIGHTDOWN : MOUSEEVENTF_RIGHTUP;
		break;
	inputEvent.mi.time = 0;
	inputEvent.mi.dwExtraInfo = GetMessageExtraInfo();
	SendInput( 1, &inputEvent, sizeof( INPUT ) );
void InputDispatch::SendKeyClick( MouseKey key )
	SendKey( key, KD_PRESS );
	SendKey( key, KD_RELEASE );
Menno
Post by Menno »
We've made a change in v7.0.2 to enable plugin developers to prevent arena from showing of the splash screen. If you provide --nosplash as command line argument resolume will not show it o7
AngeloDV
Post by AngeloDV »
Great, thanks!
subpixel
Post by subpixel »
Where do the printf()'s go to? I think Ronan suggested to the Output window (in Visual Studio), however it doesn't seem to show any plugin printf()s, eg for shader compilation errors.
joe5280
Post by joe5280 »
I've just run into the same issue today.Got it running inside the debugger but I can't see the output of cout or printf.
