Trigger Random Clip Buttons
subpixel
Post by subpixel »
Layer Random Clip Button
Similar to the Trigger Previous Clip and Trigger Next Clip buttons in the Layer Transition Controls for each Layer in the Deck.
When you activate (by mouse click or shortcut), a random Clip from the Layer is launched.
Maybe put to the left or right of the existing Layer Prev/Next buttons. Can we afford that to be one button wider?
Group Random Clip Button
Similar to the Trigger Previous Group Column and Trigger Next Group Column buttons in the single row of controls for each Group in the Deck.
When you activate (by mouse click or shortcut) the Group Random Clip button, all the Layer Random Clip buttons in the Group are activated. Maybe have separate buttons for all Layers in the Group, and only the currently active Layers (layers with a clip loaded) in the Group.
New Layer option to Ignore Group Random (similar to Ignore Column Trigger).
Composition Random Clip Button
Similar to the Trigger Previous Column and Trigger Next Column buttons in the single row of controls for the Composition in the Deck.
Similarly to the Group Random Clip button, when you activate (by mouse click or shortcut) the Composition Random Clip button, all the Layer Random Clip buttons for all Layers are activated. Maybe have separate buttons for all Layers, and only the currently active Layers (layers with a clip loaded).
New Group option to Ignore Composition Random (similar to Ignore Column Trigger).
New Layer option to Ignore Composition Random: Group Determined, Ignore, Follow.
