Hi all,
Should be nice if during the midi mapping process, we could select the item target thru osc command.
It will allow to quickly automate the midi mapping of a bunch of clips, faders (and so on) very fast.
OSC select while midi mapping
Audio-reactive Led designer
https://visualsystem.org/
https://fr.linkedin.com/in/pierre-gufflet-07803697
Re: OSC select while midi mapping
Seems like it would be a lot of extra programming on the dev's and it would probably be pretty clunky. And you would probably be the only user to use it, and after a year or two, I would bet you would probably not even use this request anymore
I know my work flow and styles change on a month to month basis.
I give this a -1 vote. Sorry
Ahah thanks for your post.
That's OK, I made a openframework app to generate all the midi mapping in XML on all clips columns and all what I needed to map in some plugins.
Sure i am the only one to need this feature.
Midi over network timing is much more efficient and accurate than osc
