I am setting up a new composition with lots of shortcuts for a MiDI Device and a Keyboard with normal keys and even ctrl, shift etc. functions. So its easy to loose track where all my shortcuts are edited especially when you work in a team and other guys want to use it too.
Is there a possibility to have some commentary field while hovering over the clip, layer, whatever and it shows you a commentary like the simple shortcut? Or maybe some connection to the Help View where it shows a commentary.
It is not be super important but with my problem it would help a lot especially the rest of the team who are not involved in the setup process.
Thanks and Cheers,
Chris
P.S: Sorry if my post might be in the wrong Subforum, not a big Forum writer.
Commentary function
Commentary function
Last bumped by CW1207 on Tue Aug 24, 2021 18:48.
