Resume Playback at Startup?
massta
Post by massta »
Thought there was a setting to start Column 1 at Startup. That would be nice. If not, I'll move this to the request thread.
Re: Resume Playback at Startup?
You can do this on a per layer level. How many Layers do you have? Some of my installs have 12-18 layers, so it takes a min to go through and trigger first clip on comp load, but it works like a charm.
massta
Post by massta »
How are you doing the auto triggering? I am not using any show control for this install. I've been using AutoHotKey so far which does work. Would be great to have task scheduled OSC or MIDI commands. How about a Resolume StartUp Batch file that self triggers commands?
Right click on your layer and then chose load first clip
https://resolume.com/support/en/layers# ... ip-on-load
For timer based triggering I use this:
https://gumroad.com/l/trigger_demo_pixel_party
