-push pull button for bpm (like pitch buttons on cd-players)
-Fine bpm adjustment buttons
-A search function for Files and Effects
-BPM animated Effect-Opacity Slider
- In and out points in Opacity / Effect Opacity like as it is or Playhead / Parameters
-Different savable / midi callable presets for the effects
-Effect Subcategories for better overview
-different Fadercurves like the V4 (logarithmic (spelled right?) for more "bouncing" Parameter automation / Loop Playbacks)
-A real loop recording / resampling function (record exactly the lenght of active layer from in to out point) for fast loop resampling with effects.
-real multi monitor support with soft edging....
-saveable "Environments"or Snapshots (Complete Surface with all settings,decks,Faders....) for loading one Style by pressing one button
-Ethernet linking Function: Link several Resolume PCs together with different fitting Material in the Decks and work only on the Master(Like the Vidnet, but for the controls).For example:
By clicking Deck 1 File 1 on the Master to Layer 1 the Slave does the same but with different Material. Ok you can do it by midi....but which Controller can control everything in the Prog ?
My Idea ist to have one Master PC I Mainly Work with and Connect several Barebones with different but fitting Material for more Screens with different output at the same time.
-BPM Analyzer like in Videojockey. For all that simple Four on the Floor Music it works quite fine..no more tapping, no expensive/hard to get/additional hardware to carry Red Sound Audio/Midi synchronisor
.....perhaps I can work with some of these features in further versions ?
Greets Maze
