Loading default decks on initialize
jordi
Post by jordi »
How can i load some default decks when i just start resolume 2.41?
I tryed to do it this way:
1 - I copied the deck in the decks folder of Program files(x86)/Resolume2.41/decks/
2 - I changed the resolume.ini from the folder of Documents and Settings:
Code: Select all
                                        [startup]
                                        firsttime=0
                                        deck1=nums1.dck
                                        deck2=nums2.dck
Is it the correct way? this has to work this way?
If not which is the way? It seams that by default it can open the demo1.dck and demo2.dck.
Thanks!!!
VJair
Re: Loading default decks on initialize
Post by VJair »
congratulations for trying much harder than is nesicary ;)
load the deck you want to autoload, then right click on the deck tab . choose ON STARTUP and then choose the deck name which will appear in the next menu on the right.
in this example my deck is called 01 ( yes, thats an an imaginative name ;) )
done.
jordi
Post by jordi »
sometimes small problems seems to be harder...
thanks man!!!
