clip preview thumb with fx applied
Rene
Post by Rene »
is there a way consider effects attached to a clip when creating the preview picture of the layers/decks?
I've 5 different "versions" of a single clip in a layer. Applied different effects on them (the outputs of the 5 clips are completely different) but the previews look all the same. Is there a way re-create the thumbs after all effects are assigned?
