Hi!
Just a quick question. Will Resolume 3 run on the new (non Pro) MacBook?
http://www.apple.com/macbook/specs.html
Tech Spec says: NVIDIA GeForce 9400M graphics processor with 256MB of DDR3 SDRAM shared with main memory
New MacBook for R3?
Re: New MacBook for R3?
Yes we have tested Resolume 3 on the new MacBook and it runs fine.
Note that it does not have a tv-out anymore so you,ll need to buy a scanconverter that does vga to s-video/composite if you want to connect it to a video mixer.
perfect! - Thanks for the info. I've noticed already that apple kicked the s-video out
bad guys! - however a scan converter will do the job (or better: the new V8 - sometime)
does anybody know if a cable like this :
(plus the Displayport to vga adaptor from Apple) will do the job when using the new MacBook?
or do I really need a scan converter?
thanks in advance
thanks in advance
doesn't seem to work...near wrote:does anybody know if a cable like this :
http://discussions.apple.com/message.js ... ID=8346023
what about the mini display-DVI adaptor, and the DVI-video adaptor. anybody knows if this will work?
My Macbook pro has been stolen, and I'm thinking in getting a new macbook instead. performance?
cheers
Incuf
www.myspace.com/eyeburner
cheers
Incuf
only scan converter works
has anybody tried out the new MBP with resolume3 over a long time??
i haven't used it yet with R3, but i am wondering how hot your MBP gets. i noticed that the left corner of the MBP (close to its screen) gets fairly hot when doing intensive work, like rending a video. however, it cools down quickly too after a render job.
i am just wondering what happens when running the MBP maxium power over a longer period (4-5hours)?? would anyone recommend using one of these? or is the heat nothing to worry about??
Really a scan converter is needed? Why can't the minidvi adapter be used? I was told at tekserve that the mini display adapter would work but he didn't have anything to show it to me on.
has anyone tried to connect matrox dualhaed to go to the new macbook pro . Is the graphic card going to be compatible with the mini display adapter ???
MBP 2,4Ghz NVIDIA GeForce 9600M GT, Amsterdam, The Netherlands
