When R3 is running my windows Task Manager shows the processor activity at 35% to 50% and the mouse movement is not smooth, even when I am not running any clips. I do not have anti virus or any other applications running. Is this normal
Processor activity
Processor activity
Laptop Specs: Pentium P4 3.2ghz dual processor, 1gb ram, 60gb 7200rpm hard drive, Mobility Raedon 9600 video card with 128mb ram.
Thanks.
Culturecide
Re: Processor activity
hmm... my only guess is the 1 GB ram could be too low, maybe bump it up to 2GB and see if that helps?
is there a lot of hard drive activity? is the mouse the only thing that's not smooth"? how bout the clips, are the effects / transitions smooth?
also, are you running XP? Vista is not very good for optimized performance in my experience.
