Master Output on 2nd display is jamming and 'flicking'
neddy
Post by neddy »
Before you ask, all my drivers are up-to-date...
I'm running a Compaq Presario V6000 -- and omegia drivers....
When i look at the output monitor in resolume it looks fine, but when you actually output to a fullscreen or windowed display it just flickers and plays about the first half second of a clip over and over again...
Does anyone have any ideas, or suggestions for graphics card settings???
I'm running a nVidia Geforce Go 6150.
We need to use it for a gig tonight also.
Cheers.
GeeEs
Re: Master Output on 2nd display is jamming and 'flicking'
Post by GeeEs »
Hi Neddy,
When Avenue can't run on specific graphic chips it wil give a message at startup, so it -theoretically- should work... but... the Gforce Go 6150 is an onboard videochip from around 2006 and thus a bit "old".
What resolution clips do you use in Avenue? And what codec is used to render these clips?
On the HP forum I read that this chip is from around 2006, and it's possible to play games (from around 2006) on 640x480 on low-low settings....
While Avenue is a very GPU intensive program... My advise... Get some more graphic power, or try using Resolume 2.41 with his laptop if it's the only thing you can get before the coming gig!
Maybe you could try real low resolution (320x240!?) clips in Avenue... not sure, but worth the try....
