dxv problem
patadeperro1
dxv problem
Post by patadeperro1 »
Hello, I installed the dxv codec and I can see it in my list of codecs in QT but when I try to export with it I get this error message: error 2091 - an unknown error occurred...I had the dxv codec installed previously ( i just reinstalled windows) and had exported a batch of files with this compression with my set up before but now these files no longer able to play either in QT or Resolume....its as if the dxv codec where installed wrong or something...is this possible?
I am running 2 windows with my resolume windows on drive D and my video files on drive c...
hope you can guide me to a solution, I dont know what to do at this point...Pata de Perro
HerrNieDa
Re: dxv problem
Post by HerrNieDa »
someone posted problems with the codec before!
try installing quicktime in the default folder....
maybe you shoult install it to your c drive.
