i think i found a problem with external audio in:
i try it on 2 different machines always win xp3
both machines use realtec intern hd audio and both found it in resolume preferences
both machines drive the extern sound for some minutes and then it´s gone...
input is still visible in pref. but no sound in same in both machines, tried it for round about 4hours, so i check my m-audio usb devise on both machines same thing... no extern audio in...
with 3.1.1 no problem with extern audio in...
...anyone the same prob???
greetings
3.1.3 extern audio in problem
Re: 3.1.3 extern audio in problem
...sorry systematically failure from my side
problem with soundcard line in settings
everything works fine now
...ok finally after playing around i found it´s simply that the extern audio most times not initialise itself
i have to switch to "no audio input" and then simply switch back to "my audio in devise"
...thats it then input is aktiv and everything triggers fine ; )
