Hello there,
After having reinstall some Nvidia drivers, I now don't seem to be able to get 3.1.3 or 3.2 to redraw or effect the output pane - preview pane - or external display. It shows a grab of whatever the display was showing before. (Desktop / other app etc etc.)
I'm on windows 7 and have used several different drivers.
Are there any other Nvidia settings I should be watching?
(I've tried 'Compatibility & Peformance Mode')
Can you help?
Many thanks,
P
Preview and Output not Drawing/Refreshing
Re: Preview and Output not Drawing/Refreshing
I've just used the Driver Sweep and reainstalled the latest drivers for the 7950 Go Card
Still no luck
Still no luck
After trying all sorts, turning on' Aero' mode - or at least a windows theme that supported it, appears to have brought back the drawing for the video panes.
I had been using the Classic windows theme.
Phew.
Does anyone have any more detailed experience with this Aero nonsense?
Phew.
++ PUSH!
Why do the windowsstyles affect Resolume?
Greets
Greets
ADD:
Aero Winstyle ON = non fluid videos with no tearing
Aero Winstyle OFF = very fluid videos with tearing
example:
Any solutions?
example:
Any solutions?
