Avenue and lighting control software on same PC?
sjp
Post by sjp »
I was wondering if anyone has used Resolume and
Chamsys Magicq PC(or similar software on the same computer, controlling via Artnet?
I used to do this all the time with Arkaos VJDMX.... is it possible here?
dbassix
Re: Avenue and lighting control software on same PC?
Post by dbassix »
Might be possible, if u set your ArtNet Node to Localhost (127.0.0.1)
sjp
Post by sjp »
yeah, i was thinking the same... also the way i did it with Arkaos, and apparently this can be done with Wholehog pc software, is to install the Microsoft Loopback Adapter. Originally a troubleshooting software tool, it provides for local feedback of network signal...
Anyone out there try this with resolume??
doing a trial setup, i'll postback for anyone else interested in results...
dbassix
Post by dbassix »
I wouldn't recommend to them on one system, as for performance issues.
