Hi
I use the latest Resolume Avenue demo, but when I try to load clips that are encoded with adobe media encoder, they always go to BPM mode (even if there is no music). When I do the BPM to 500, the clips play at normal speed (so long clips are like 20 beats, short only 2 beats, but when compared with the timeline, 500 is "normal" playback speed)
Is this a bug? Or is there a way to remove all the audio BPM stuff (I don't really use it).
Alfaleader
Avenue clips encoded by Adobe always go BPM sync
Re: Avenue clips encoded by Adobe always go BPM sync
i hab this "bug" (bpm was too slow)
the problem happens sometimes if the audio settings are set incorrectly and after selecting the right in/out resolume makes this strange bpm behaviour
you must restart resolume and delete the preferences.xml in your "user" resolume folder before!
hope this helps.
that media encoder encoded clips always set to bpm sounds strange, would be a nice "feature"
hope this helps.
Can you please send us one of the video files so we can test it too? support@resolume.com
But most likely there is a silent audio track in the video file that causes this. Resolume by default loads a video file with audio in BPM mode. Note that you can just remove the audio on the clip panel or set the clip back into Timeline mode.
